2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2016 Posts: 5 New Guy | | New Guy Joined: Dec 2016 Posts: 5 | While pulling distributer the nut clamping the vacuum advance went down the distributer housing. while trying to retrieve it it fell into the rear galley. I'm pretty sure I heard it hit the side of the oil pan and fell into the bottom. Should I pull pan or is it relatively safe in the bottom of pan?
1942 6 cyl 216ci engine
What an idiot?
Any comments would be appreciated.
Thanks | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Pull the oil pan drain plug and fish around the bottom of the pan through the hole with a flexible magnet. Chances are you'll get the nut out that way. If the nut is in one of the splash-oiler troughs it can do some damage to a rod dipper the first time the crankshaft turns. Jerry
| | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Of course, pull the pan. Why take the chance assuming anything?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Get one of those really strong little magnets and try to coax the nut close to the drain plug from the outside on the bottom of the pan. It should drag the nut toward the drain hole. You can test the procedure on a scrap piece of sheet metal and a similar sized nut. Carl
| | | | | Joined: Sep 2016 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2016 Posts: 31 | If you have by chance access to one of those endoscopic cameras you might give it a try down the distributor hole or if that doesn't work out through the drain plug hole. If in the end you don't succeed you can pull the pan anyway. Not much more to lose than some time if it doesn't work out that way. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I was able to R&R the oil pan on my 49 216, in truck, without any clearance problems. It weighs more than you think but I done it laying on my back underneath. I'm unsure if the 42 has the same clearances. If you haven't dropped the pan before it is a good time to do so and give the innards a good look-see. Plastigauging the bearings will tell you how much life you have left in it. May even still have some main bearing shims you could remove to gain more oil pressure.
All that said, fishing around with a long handles magnet and/or one of those mini endoscopes "may" save you a lot of work.
Good luck Dave | | | | | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Good excuse to clean the insides of the pan. Maybe you'll find the missing wedding ring of the previous owner's wife? You never know.
| | | | | Joined: Dec 2016 Posts: 5 New Guy | | New Guy Joined: Dec 2016 Posts: 5 | sorry for the late reply. removed pan found nut and many other items. after a little thought I surmised that they were 4 fuel pump arms. this must be a usual occurrence and that the pan had probably not been pulled in years if ever. Didn't think of plastic gauging bearings. I could use some more oil pressure. How much pressure does an old "42" 215 run anyway? | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | A 216 does not have pressurized oil to the rods, so tightening up the clearance there doesn't help oil pressure. It will make the engine run quieter, however. Shoot for .0015"-.002" by removing shims between the rod and cap, and checking the clearance with Plastigauge or shim stock between the rod cap and the crankshaft.
Pulling shims between the main bearing caps and the block will increase oil pressure by minimizing the leakage past the bearings. Again, try for .002" or less if possible. The cam bearings are another story- - - -wear and oil pressure loss there cannot be corrected with shims.
If you have 15 PSI or so at cruise speed with a warmed-up engine, be happy. Some 216's show virtually no oil pressure at hot idle and still run pretty well. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My 1951 216 runs well under 15 lbs on the highway and almost zero at idle. It hasn't really changed in 35,000 miles of driving. The main bearings are new and are adjusted to minimum clearance. I think the cam bearings are quite worn. My 38 oil pressure is off the scale when cold, over 15 lbs when cruising and not much below 7 at idle. So these old 216s have vitals that vary widely.
As far as adjusting the rods, if you still have the pan off it is a good idea. When they become too loose they can wear out very quickly. | | |
