2 members (Erniegp, J Lucas), 89 guests, and 2 robots.
Topics128,054
Posts1,055,781
1 Offline
I bought a new starter for my truck from NAPA, seeing as my other one wouldn't work. I can get the starter to whirr up and the starter gear to move forward but it seems like it won't mesh with the flywheel.
NAPA part code?
6v or 12 electrical system on your truck?
What year engine/flywheel on your truck?
1 Offline
its a 6 volt. it has a 235 ci. it was the only starter NAPA had for my truck
1954 235 with a 1954 GM 4-speed manual transmission?
It's more likely you've got a bad starter drive. Just because it's "new" doesn't necessarily mean it's "good".
1 Offline
How can i test the starter drive?
You'll need to remove the starter, clamp it in a big vise, and extend the gear by pushing the stomp linkage all the way into the "engaged" position. Clamp a pair of vise grips onto the gear teeth, firmly, but carefully so you don't break the teeth. Then connect some jumper cables to the starter hot terminal and ground (yes, there will be sparks!) If the drive unit is good, the armature will not turn- - - -disconnect the cables immediately. If the starter shaft spins, you've got a slippy drive unit.
