3 members (KEVINSKI, Otto Skorzeny, 1 invisible), 71 guests, and 0 robots.
Topics128,108
Posts1,056,567
Members48,448
#1208378 03/13/2017 7:07 PM
1 Offline
I got a 54 3600 with the 235/hydramatic from my uncle as a project. It is fairly rusty, but isn't that bad. Id prefer a 4x4 so im just wondering what the easiest way would be.
The easiest way would be go buy a 4X4.
Your Hydra-Matic truck is unique and somewhat rare plus it has a family history. I say get it running and stopping and drive it a while before making any decisions.
Leave the 54 alone and go buy a 4x4.
Crusing in the Passing Lane
If you told us what part of the country you are in, it might help?
Ed
1 Offline
I live in central mn
There is a site that is dedicated to NAPCO 4X4 units that were available as retrofit kits before the factories produced 4X4 trucks. I'm more familiar with Task force era trucks, but I believe there were kits for your era trucks as well. Try googling NAPCO 4X4. That would be the most direct way to do it. Ive seen Advance Design trucks with Blazer or Jeep truck drivetrains or even modified frames under them. Thats a lot more work and takes more engineering to make a truck that works well. Good luck.
LJ
I even found some factory wide front fenders for my 47.1 GMC when I made it
4wd so I could use a Blazer front axle, so they do exist.
Ed
1 Offline
I have another question then about the NAPCO conversions. I've been reading and it seems like they were available for my truck but are pretty rare. I am just wondering if they are available and how expensive they are?
Given that they became available at the very end of the AD run, they very rare. I believe they were only available in the 3/4 ton and bigger trucks. If you do find the entire setup, good luck finding replacement parts. You will need them.
Another thing to consider is what do you want to do with it? They are not up to modern standards for 4-wheel drives. Some of them came with full time 4X4, others had lockout hubs which you have to get out to manually engage the front hubs.
One would make a nice museum piece, but I would not enjoy one as a daily driver.
Carl
A NAPCO conversion for 1954 trucks was available from NAPCO as an after-market conversion - they are listed in the GM 1954 Chevrolet Truck Silver Book, and other 4WD conversions were available earlier during Advance-Design productions years.
They'd be very rare.
1 Offline
I was out working on my truck today, trying to get it to turn over. I hooked up the positive battery cable to the starter. My truck has a key and a push button starter. I turned the key and pushed the starter and it turned on. The problem I'm having is that it seems that the gear on the starter moves forward but it wont engage with the flywheel. Just looking for some help on this one.
