| | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Is there an updated easy to install synchro 3 or 4 speed tranny that would pretty much fit my 1/2 ton Chevy truck with floor shift and a torque tube driveshaft ? Or do I have to go to an open driveline first ?
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Is there an updated easy to install synchro 3 or 4 speed tranny that would pretty much fit my 1/2 ton Chevy truck with floor shift and a torque tube driveshaft ? Or do I have to go to an open driveline first ? Yes, any 1948-1954 truck 4-speed will be synchronized in up-shifts, and in down-shifts (except maybe from 2nd to 1st). The standard 48-54 3-speeds would be column shift. | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Tim...does your "yes " refer to having having to change my torque tube to an open driveline first .....or .....does your yes refer to having a tranny available in 4 speed as an easy fit ? I currently have a 318 3 speed that has been moved from the column to the floor by the previous owner. If I installed a 4 speed from the same era 1948-1954, how is that an improvement ????
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Sorry, You asked about enclosed driveshafts, and my answer responded to that.
I should have been more specific: Yes, any 31xx series 1948-1954 truck 4-speed will be synchronized in up-shifts, and in down-shifts (except maybe from 2nd to 1st), AND, they should have the torque-tube cover on the rear of the transmission (easily confirmed by looking at the rear of the transmission).
The rear enclosed u-joint cover/housing on the 4-speed is swappable/changeable with an open drive-shaft cover/housing.
I do not know what improvement you are looking for: high end or low end. The high gear in both transmissions (and in the 318 3-speed) is 1:1.
