6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#120901 06/19/2006 3:09 PM
The 72 GMC I just bought was owned by a contractor who had his company info on the side of the doors in stick on vinyl lettering. How do I remove the vinyl lettering without harming the paint?
53 Dumpy
1951 Chevy 3100 "Ernestine"
1970 Chevrolet C10 "Ol' Blue"
1940 JD "long-hood" B
1959 Jeep FC-170
1960 IH B275
2013 Chevy Silverado
2023 GMC Denali 2500HD
#120902 06/19/2006 3:42 PM
the only way stuff like that might come off is to heat the vinyl with a heat gun, carefully pick away at an edge to get started, and peel each letter off
not much chance of getting it all off, especially if the lettering has been on for a long time - also remember that the paint under the lettering has been protected from UV, so if you do get it off, the difference in the paint will make it look the same as before!
much easier to just sand the doors and repaint
#120903 06/19/2006 5:12 PM
Anonymous
Unregistered
Anonymous
Unregistered
I'm not certain but I think they use some type of rubber wheel you can put in a drill.I've seen this used on pinstriping.
#120904 06/19/2006 5:55 PM
Contact a auto body supply house they will have the tool skippy was talking about
#120905 06/19/2006 6:33 PM
The rubber wheel for a drill is called an 'eraser' and it is used to remove pinstriping and vinyl decals.
After you've got the decals off you'll probably need to hit the rest of the door with rubbing compound/polish, etc... to get everything looking the same- I really like the McGuires products for that.
I wouldn't try the heat gun 'cause enough heat to loosen the decal is probably enough to damage the paint. If you are stripping it anyhow, you might not care though.
#120906 06/19/2006 6:55 PM
We use the eraser at the dealership to remove decals for the customer or to replace a defective one. They dont remove paint or even scuff it as I can see. The greatest thing since WD 40 in my mind.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#120907 06/19/2006 8:27 PM
the erasers work great, but if there is a lot of decals you will be there a while. All of them I get are always plastered front to back with enough stickers to make a rice grinder jealous. Take a good hot sunny day, spray on some soapy water & use a razor blade to get a corner up, then peel them off slowly. most of the larger business decals come off pretty easily. you can also buy a plastic razor blade that won't scratch. use 3M adhesive remover for any leftover residue, won't hurt paint. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#120908 06/20/2006 5:39 PM
A hair dryer set on hot and plastic razor blades work the best. You don't even need the razor blades just heat the decal with the hair dryer and start peeling.
Wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#120909 06/20/2006 5:54 PM
and be sure to let us know your results!! grin
#120910 07/01/2006 12:08 PM
Do not use a heat gun. The missus hair drier will do just fine. Just take your time peeling the vinyl. I can guarantee that the letters will leave a glue residue behind. Use mineral spirts to remove, as lacquer thinner will damage the paint. Also, if you have to remove lettering that has been professionally painted on with lettering enamels(One-Shot), Easy-Off oven cleaner will do the trick. Test an inconspicuous area first....
Andy
A man is like an old truck... He will rust out before he wears out...
