10 members (stlcardinalsguy, joe apple, Wally / Montana, King Kielbasa, Hotrod Lincoln, Otto Skorzeny, DennisM, Wayne67vert, kades51, 1 invisible), 87 guests, and 1 robot.
Topics128,052
Posts1,055,727
#1208901 03/16/2017 8:46 PM
Hi all,
today I made a 70mls roundtrip. After this run I checked the spark plugs.
The #1,#2,#3 spark plugs looked like this:
http://www.bilder-hochladen.net/i/m0et-1-6e50.jpg
The #4 and #5 looked like this:
http://www.bilder-hochladen.net/i/m0et-2-9010.jpg
(Slight off focus, but the colours are ok)
And #6 was this:
http://www.bilder-hochladen.net/i/m0et-3-5429.jpg
I am a bit puzzled about the cause for such a difference. Any suggestions?
H Online: Content
1,2, and 3 are running slightly lean. The others are normal. Look for a vacuum leak that might be affecting only the front cylinders- - - -possibly a loose or slightly warped intake manifold? I use an unlit propane or acetylene torch with just a little gas flowing from the tip to find small vacuum leaks. Pass the torch tip along the cylinder head/manifold mating surfaces, carburetor base, etc. The engine will speed up or the idle will smooth out when the gas finds the leaky spot.
Nice, Jerry - Thanks
I was going to BS bad valves over some of the cylinders (check compression), but this is out of my simpleton league.
Helmut, please let use know what you find.
Hi Jerry,
thanks for your advise. I might already have a suspect:
http://www.bilder-hochladen.net/i/m0et-4-7a42.jpg
I've no gas torch at hand right now, but will check as soon as possible. But since the intake ports are paired, wouldn't a leak which affects cyl. #3 also affect cyl. #4?
Further question: Will it do any harm to the engine if I drive the truck this way?
