| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 27 Junior Member | | Junior Member Joined: Dec 2005 Posts: 27 | I have a 48 1/2 ton gmc that I am replacing almost every panel on the truck. when I got the truck the floors and door pilers where rusted away. the cab has fallen or something I got new floor pans with the toe boards and they will not match up there is about 1 1/2" between the two. I also got new rockers and inner cowls and outer cowls. is there some way to get the truck square so the panels fit better? any help would be great. or everybody can come to my place and we all could do it together? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 48, that is the way mine was when I got it. If you look up my webshots you will see how I supported the cab to do the work. I copied the method from the "Chuck the truck" website.
There are cab supports underneath the frontfloor. If these are rusted out, the cab can end up resting on the bell housing via the toeboard. | | |
