9 members (mick53, Peggy M, Southerntruck, Gdads51, LAROKE, NJC, 68ironhead, dt235sd, GMCJammer51),
158
Mod | | | Forums66 Topics128,091 Posts1,056,393 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2017 Posts: 28 | http://rs1235.pbsrc.com/albums/ff427/454NOVA/GMC%20450/thumbnail_20170304_1108221.jpg~c100?t=1489299173 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 |
| | | | | Joined: Mar 2017 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2017 Posts: 28 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Are you going to keep the fire truck bed on it?
If not, there is an inline pump with disc brake(probably) that you can remove and replace with a Brownie, OD, transmission, to help you with road speed, if you need it. Make sure to get a Brownie with attached brake, Tru-Stop is popular, so you will have a park brake.
Ed
| | | | | Joined: Mar 2017 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2017 Posts: 28 | I posted some answers on the Fire Bolt Forum and some back side pics on the Big Bolt Forum | | | | | Joined: Mar 2017 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2017 Posts: 28 | I'll have to evaluate the truck before I make a final decision on "bedding" the lady. I have been looking at the P30 swap and have a local with an aluminium roll back on a blown up truck. Wheelin an Dealin if it comes to that. I have a fresh old school built 454 ready if necessary but it won't make a good long haul motor. I/4 mile deliveries would be a snap though. | | |
