6 members (frogfarmer, Gray_Ghost, dunfire, Otto Skorzeny, jay d, 50Chevy3100), 81 guests, and 3 robots.
Topics128,056
Posts1,055,804
Are the windshield frames the same between the civilian trucks and the military versions i.e. G506 and GMC CCKW. ? Thanks
My best guess would be yes and no. A few years back, I was salvaging a door for my 39 3/4 ton JD chevy from a large military truck from the 40’s in a junk yard. It appeared that the cabs were the same and the door worked fine. My best recollection was that the windshield frame appeared to be the same size but the mounting hardware was different. Instead of crank-out, there were sliding brackets with lock down bolts on the side.
Hello Gents, the windshield for the 41-46 4109 is the sames as the civilian model with the same style of windshield crank, however the CCKW and G506 have adjusting arms attached to each side of the frame similar to a WillyS MB or FORD gpw.
