1 members (VicZ),
231
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I am getting ready to replace the fender closing panels on my 61 and I need to attach the rubber seal to the panels.
The closing panels that are on the truck now have the seal attached with staples through the seal and the panel.
Does anyone know a way to do the job where it will look original?
The new panels and seals have no holes and even if they did I don't have a stapler that would handle that kind of staple.
Suggestions or comments welcome, Thanks, Hobert
"The Lord is my shepherd"
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used Arrow T-50 stapleguun staples,, 1/2" long I think. they match the old holes like a charm. I installed them manually using needlenose pliers, use a hammer for final tightening,,when done looks like GM did it. brian | | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | Thanks Brian, I got one side done using your method and it does look like the original. I used stainless steel staples from Lowes to keep them from rusting!!! Thanks again, Hobert
