2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
I have not been on for awhile...so I may need help getting into the proper category. I have a 1949 chevy coe with a 270 GMC motor which needs over hauling, or replacing. Maybe frist are parts available for the 270? I have a good 292 chevy motor. Will it fit without much modification. Should I think about replacing with a v-8 (350)or something comparable to obtain 60 to 65 mph highway speeds.
Thanks for any help.
Your title does not match your question at all. I'm confused.
1951 3100
Crusing in the Passing Lane
Your highway speeds are determined by rear axle ratio, right now if you have a two speed rear axle, your speeds are slow and slower, so you need to change your rear axle. No rear axles with that bolt pattern are available, get a modern rear axle with that bolt pattern.
270 and 292 are about the same length, however the updraft carb and associated manifold would be hard to make happen on the 292. An OD trans. will solve your highway speed problem, if you have enough power to pull it.
Where in CO are you located.
Ed
His question was added to a thread in General Truck Talk that had nothing to do with his question. I changed the title before separating it but for some reason the title stayed the same. It's a quirk in the software.
Hi ED,
I am in Eaton
