| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Good morning. My son recently picked up a 235 that a gentlemen pulled from a 1953 Chevy truck. I've gone to numerous sites trying to decrypt the date/source of the engine. There are a few oddities that make me question my findings. The first is that the engine is currently orange. Obviously, someone may have painted it over the years. The second is the engine serial number stamped on the plate next to the distributor. It ends in a B. One source I found for this indicates a passenger car? But the code on the block indicated a truck. Here are the codes....
3769716 (1958-1962 truck) CON4 L131 (Dec, 1961) B54 848 850 (???) GM16 FI214B <--- (Flint, Dec 14?....B???) 383648 GM23
I'm guessing it's out of a 1961 or 1962 truck. But the FI214B and orange color have me questioning that.
Thanks in advance!
Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ron & Ryan, An orange engine is a strong indicator that the engine has been rebuilt and then repainted, or, it has only been repainted. If it is a replacement engine, the Engine Serial Number might not have been put on it in the factory/assembly-plant. What are the head codes? | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Thanks Tim. When you say, "if it was a replacement engine", you are indicating that it wasn't put in a vehicle on the assembly line and just "shelved" until needed? Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I used "if" as a conjecture that might explain the odd code. Just a guess.
Let's see what year the head is from? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | F1214B; F Flint plant, 12 14, December 14th, B Regular Passenger 235 w/Powerglide.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Perhaps, it should be noted that the format that Bill decoded was used from 1957 onwards.
F - Flint, MI plant 12 = Dec 14 = 14th B = 235 Passenger w/Powerglide (was this code used through 1962/63?)
(it should be noted that a Powerglide transmission was available as an option w/235 in some small trucks in the early 60s; I think its code was JB)? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Conveyor Belt Number at FoundryCON4 = Conveyor 4 Engine Block Cast Date CodeL131 L = 12th letter in alphabet = 12th month in the year = December 13 = 13th day of the month = 13 1 = last digit of 1961 Date block was cast on, December 13th, 1961 This engine probably went into a 1962 year's model passenger car. Block casting Number3769716 = 1958-1962 235 cubic inch Engine Serial NumberFI214B F = Flint, Michigan - Engine assembly Plant I2 = 12 = 12th month in the year = December (Sometime the letter I (eye) die stamp was used as the number 1 (one). 14 = 14th day of the month = 14 Engine assembled on, December 14th, 1961 1961, B = Regular, Powerglide transmission RPO 313 = Regular Production Option 313, Powerglide engines used Hydraulic lifters 1962, B = Regular engine, Powerglide, RPO 313 A high percentage that this engine was:Cast in Flint Michigan on, December 13th, 1961 Assembled in Flint Michigan on, December 14th, 1961 Made as a straight six cylinder 235 cubic inch engine. A Powerglide transmission was mated to it. Has Hydraulic lifters. Was installed into a 1962 model year passenger car. Its painted orange. 1961 Passenger car GM Vehicle Information Kit or restoration pack. 1962 Passenger car GM Vehicle Information Kit or restoration pack. Tim, I looked at every passenger car resto pack from 1950 to 1965. From 1957-1964 they use code B for RPO 313 Powerglide transmission. 1965 code is FM | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the correction, Jorb
What was the meaning of the truck code JB and JH, used on C10-20 with RPO 311? MA designated an 8-cylinder engine with the Powerglide, I think. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Tim, I meant to say, I looked at every passenger car resto pack from 1950 to 1965. I'll look at the truck resto's to see if I find anything. . | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Thanks guys! I sounds like it was from a passenger car and that would explain the orange. I thought I had seen in a couple of places that the 3739716 was from a 1958-1962 truck.... 60-61 Chev Trk 1958-1962 235 ci truck Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ron & Ryan,
The second link is from my website. I obtained that information from a variety of places - they could be incorrect.
Yes, that engine casting code was used from 58-62 on truck 235s; but/and, that code was used on both car and truck 235s in 61 & 62 (as shown on that webpage). | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Tim, I don't know if this helps: The 1961 Chevrolet Truck resto pack from GM Heritage Center. Shows on pdf page 10, Engine ID, JB and JH JB, was stamped on engines in C 10-20 series trucks with RPO 311 JH, was stamped on engines in P 10 series trucks with RPO 311 Now go to pdf page 30, "Regular Production Options" page It shows 311 Powerglide transmission, C 10-20, P 10 I think the Powerglide RPO number for the passenger car were different than the Powerglide RPO number for the truck. 313 car 311 truck I have even seen a 317 Powerglide RPO for early 50's passenger cars. So it seems the Powerglide RPO number changed periodically depending on what the application was, truck, car, year. I'm not sure, but I think this is what you were looking for. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good info (as usual), jorb. Thanks. | | |
