1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#1206754 03/03/2017 5:26 PM
I was thumbing through the FATMAN catalog, saw they had an 8 lug IFS setup.
I'm going to assume that it is based on their 60" kit that uses 73-87 C10 spindles.
At $3500, it's a little pricey. But does have some cool factor.
Check out page 22
http://www.fatmanfab.com/wp-content/uploads/2015/11/WholeCat_web.pdf
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #1208064 03/11/2017 11:52 PM
I've been looking for something like this for a while. It does seem pricy but might be worth the money. I guess i need to do more research. Thanks for sharing this info.
Whitedog #1208115 03/12/2017 4:00 AM
Crusing in the Passing Lane
C-10 did not come with 8 lugs, they must be using 3/4 ton wheels on 1/2 ton spindles.
GM/Chevy 8 lug IFS could be easily adapted.
Ed
Whitedog #1208191 03/12/2017 6:18 PM
I'll throw something else out there too.
An MII setup may be easily adapted to 8 lug also.
Most MII suspensions are now using Dodge ball joints, which were used on B series vans throughout their lifespan. The Mopar vans had similar length springs, although much more spring rate.
It may be as simple as installing a Dodge front spindle and adjusting the Kingpin angle.
"The Fake Truck"
Moderated by  Dusty53
