11 members (Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible),
98
Mod | | | Forums66 Topics128,169 Posts1,057,037 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Looking for truck tread type tires to fit 16x5 steel wheels. Any suggestions? Thanks | | | | | Joined: Jan 2016 Posts: 1,106 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,106 | Are you looking for modern tires or vintage style. (White wall, etc...) | | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Not sure yet. For a 1930 REO truck cab that I'm turning into a panel truck with wood sides | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Cool, do you have a px?
Ed
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I put a set of LT215 85R 16's on my 49 3100 w/stock rims and they've held air and perform very well. Link | | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Thanks for the info. How do you post pics in here? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You don't post pics in here, you link to them.
Also, this site is for old Chevy and GMC trucks. Your question is way off topic and should be in the Greasy Spoon. That is also where you should post your links. | | | | | Joined: Mar 2010 Posts: 22 New Guy | | New Guy Joined: Mar 2010 Posts: 22 | I just upgraded to some late model 16x7 8 bolts to get away from the original GM 15x5 split rims (no body wants to touch them in my town). I went with Firestone's Transforce LT215/85-16. Right at 30" tall...the 235s were too tall almost 32". I also wanted more of a truck pattern...these somewhat have that look but also had the very plain sidewalls I was looking for. I'm hoping to make this my daily driver so wanted to go the way of radials.
If you find a tire you like check tire rack or simple tire for the specs on acceptable rim diameter.
1964 Chevy C20
