| | | Forums66 Topics128,164 Posts1,056,975 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 27 | Help! Looking for a diagram showing the complete proper brake line routing for a 49' 3800 Panel. The previous mechanic had stripped the entire system, so I have no reference. Everything else has been replaced to original specs. Just need the diagram. Thanks!
(2) 1954 3100's / foster parent - SOLD 1955.1 3100 Resto in progress 1971 GMC 2500 Custom / foster parent 1951 M37 Lawn ornament 1949 3800 Panel Resto in progress 1959 GMC 100 LB Fleetside
| | | | | Joined: Dec 2016 Posts: 5 New Guy | | New Guy Joined: Dec 2016 Posts: 5 | Hi Freddy518, I have a 49 Chevy 1 ton panel truck, 3805 that is completely original. Can send you pics. Paul at 252 259-7896 (text and pics) or [email protected] | | | | | Joined: Oct 2015 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 27 | Thanks Paul, Just sent you a text.
| | | | | Joined: Oct 2015 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 27 | It appears that one brake line only (Unlike my 55.1, No T block at the back of the master cylinder) comes from the master cylinder, then crosses the rear crossmember to a T which goes forward to another T, I assume to cross the front crossmember to get to the LF Wheel. Can anyone confirm this?
Thanks!
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | From master across to passenger side framerail.TEE. rearward to bracket fitting-rubber brake hose to TEE on rear axle. From tee one hard line in each direction to each wheel cylinder. Frontward from tee. Hard line to tee by right front wheel. Short hardline to bracket. Rubber line from bracket to wheel cylinder. Other end of tee. Hardline over to left front bracket. Rubber line from bracket to cylinder. Hope it helps. Fitting brackets should already be on frame. 1949 gmc 1-ton | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Try also going to. American classic truck parts and search out brake hardware. They show a generic diagram that may help 1949 gmc 1-ton | | | | | Joined: Oct 2015 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 27 |
