6 members (Otto Skorzeny, TexasJim50, joe apple, RaNfLaS, Hotrod Lincoln, Wayne67vert), 127 guests, and 4 robots.
Topics128,162
Posts1,057,065
Members48,463
Hey, I was wondering what it would take to convert a 1954 Chevy 3100 to a 3800 so I could pull trailers and load ATVs in the bed of the truck.
Hey, I'm new
At what speed?
There have been numerous post about going the other way...
Best bet is trade trucks with someone who has a 3800 and doesn't appreciate it for what it is.
•1952 Chevrolet 3800 pickup
---All pictures---
Crusing in the Passing Lane
It is easy to change the axles and springs, not so easy to upgrade the frame, etc, rather than modify a nice 3100, do as suggested above and swap for a truck already set up for your loade.
Ed
Would it require a new frame for the conversion?
Hey, I'm new
Frame could be boxed in several areas for added strength. Make sure your welder knows what he/she is doing with older metal.
Frame is also longer as is the bed. It is also of slightly thicker metal.
They're quite different trucks underneath starting with the frame and everything under it, and if you have a 3 speed the 1 ton has a 4 speed, another difference.
It's really not worth trying to make one into another, the result will never be same as what you're trying to imitate. Short of swapping 1/2 ton cab and front clip only over to the 3800 chassis and bed.
---All pictures---
Leo Offline
Moderator
Moderator
Not likely get it certified in Ontario with the new regulations. Definitely check this out.
In the last couple of months, I have seen a couple of 3/4 ton rolling chassis for sale for $200 in Arizona...one in Tucson and one in Phoenix. Both were complete with axles, springs and rims. One had the SM420 and both driveshafts.
If you can find something like this to start with, it would be easier than retrofitting your existing chassis.
Matt
It's a truck. It can already pull a trailer. How much weight is the question. And it can also carry cargo in the bed. Is your desire to convert partly because you want a larger bed?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Don't know if it'll be technically a 1 ton, but you could swap in a 3600 front axle. They use the same springs.
In the rear, you could swap in a HO52 or 14 bolt. You would need to weld in new spring perches&shock mounts.
You end up with a short 3/4 ton truck.
Like others stated, the frame is the weak spot.
The next issue is your driveline. Yourt torque tube trans will need to go.
Stopping with an extra load is an issue. There's more brake options with the 3100.
You may be better off just adding rear overloads and adding front power brakes to the 3100.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
What is the trailer weight rating of the truck? Also what would I have to do to put a longer bed on? headscratch
Hey, I'm new
Longer bed=stretch the frame, weld in boxing plates.
You may have better luck finding a 3600 or 3800 truck to begin with.
Trailer weight? No good answer, depends on your driveline and being able to stop.
"The Fake Truck"
