| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Need some help identifying a NOS GM rams horn exhaust manifold I bought at the Decatur swap meet last weekend. It's got the original paper band still on it which reads.......
GM Parts Div. 372243
GR-03.601
01D7 __________________________
The actual casting numbers on the manifold itself are:
1408 1238 (stamped just like this, one # over the other)
on the backside is the number...
13L6F
If anyone can decipher these numbers so I can know when it was made and what motor and vehicle it was originally made to fit on I would really appreciate it.
Many thanks, Chuck
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | long list of small blocks - also click application hereBill | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | The "application here" link was sort of helpful. Would still like to hear from anyone else that could lend some specific help or point me in a direction to find it myself. Thanks for your help Flxible.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | in for my casting book it is a over the counter r hand w&wo air replacement manifold or a pre 84 corvette 350 r hand | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Thank you Leonard. I appreciate the specific information!
