| | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 39 | Looks like they are making a new wheel for our trucks to replace the discontinued accuride wheel. Rim Size: 22.50 X 6.75 Bolt Pattern: 10 Hole on 222.25mm Bolt Circle, 158.75mm bore Mounting Type: Hub Piloted Dual Offset: 5.67" Material: Steel Number of Hand Holes: 5 Approx. Wt. (lbs): 92 http://www.wheelsnowinc.com/catalog/viewItem.php?id=1118 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If that's the bolt pattern you have?
Many of our trucks are 10 lug on 7.25" bolt circle, that wheel is not. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | What year truck are you putting these wheels on? 10-Lug, 8.75" bolt circle, 6.75" Hole... Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | There are lots of those wheels around.
Ed
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 222.25mm x .03937" = 8.743315"
Ed
