2 members (Gdads51, moparguy), 96 guests, and 2 robots.
Topics128,180
Posts1,057,068
Members48,460
Anyone install one? If so, comments as far as reliability, etc? Looks like only one mfg is making it. Going to make the conversion.
FYI....Im sure this is already known but if you remove the glove box liner and door, the vacuum based unit is then so easy to remove. Two screws, dash knob assembly, one clip and it is out. Easy (for a change...). All this because the seat frame is welded to the floor so tough to move on your back and get under the dash, at least on the '54, needless to say.
What year truck?
54 3100. The purpose of the post was to ask about the opinion of the electric motor, not sell parts. Sorry for any confusion.
Most/all aftermarket 1954/55st Chevrolet truck electric wiper assemblies will not work with an original-style/location radio speaker.
OK - good luck with the install.
Go ahead and delete your second post.
It was a little awkward but I was able to get on my back in my 54 and change the vacuum motor out for an electric one from underneath last year. As stated, removing and replacing was easy. The most difficult part was getting my 6' 240# frame out from under the dash and slithering across the floor and out the door. It was not a pretty site and probably would have scared small children had they seen my twisting and squirming. I wish I had thought of the glove box trick.
Dave from Northern Kentucky
My 54 3100
To ease the under-dash uncomfortability, I use a 5 foot long piece of plywood which is the right width to fit between the front of the door opening and the seat base. You will need to come up with a saw horse or a stack of something to support the outside end of the board outside of the truck (my air compressor is the right height and when it comes on, it provides a soothing vibration for my chronic lower back pain smile ).
The ingenuity of Stovebolters is why I love this hobby. I will probably butcher the quote but "necessity is the mother of invention" and no one it more inventive that the mechanics and engineers keeping these works of art on the road.
My 54 3100
Here's a question for Tclederman.....I found out the hard way that MOST wiper conversions don't work with with the radio with the speakers mounted above!..live and learn.. My question is should I send my vacuum unit off to Wiperman for a rebuild or is there any other ideas you're aware of?
The original GM 54/55st 6v electric wiper is very hard to fine (with mounting bracket).
Wiperman is the only way to get a vacuum wiper rebuilt with original parts.
I only use his services.
What other types of ideas are you looking for?
Ways to have more consistent vacuum?
- vacuum reservoir (I will try this someday)
- dual-action fuel pump (better than stock set-up for almost constant wiper movement)
Crusing in the Passing Lane
I'm glad my '54 630 has overhead wipers.
Ed
I sent mine off and had it repaired and that was 10 years ago and it is doing fine. Someone rode with me in the rain the other day and asked if it was a vacuum, he should have known, he was one of the mechanics that worked on it. Other than the blades I am satisfied with them after 27,000 miles of use.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
