7 members (1955 1 Series, Bill Trotter, Gdads51, Leo, cmayna, ShopRag, moparguy), 110 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
I've been told to slip a 1955 2nd Series to 1957 Chevy truck frame under my 1952 Chevy truck as a way to start upgrading it. Are the frame widths that close to allow this? My 1957 short bed frame is 34 inches wide. Anyone have an approximate width of the Advanced Design trucks?
Whoever told you that knows nothing about these old trucks.
Sir Searchalot
Sir Searchalot
Maybe it's me but I'm confused.
1. "Anyone have an approximate width of the Advanced Design trucks?"
"my 1952 Chevy truck" Can't you measure it? It's an AD.
2. If you have a 57 and a 52, all the answers are in your driveway?
3. Anything can be "done" with fabrication and money.
4. Not too many swaps "slip" together.
5. Regarding the subject of frame swap: This is absolutely not the way to upgrade your truck. Moving from AD to TF is not a big upgrade really. Buy various upgrades made for AD or buy a specific "modern" frame for an AD.
Glad to help if you explain a little more. Define what you think upgrade is, and what kind of truck usage you want. Someone, somewhere has done everything you can imagine but it may not have come out as they envisioned.
If I had them both in the driveway I would have measured them, but my 1952 Chevy is not here with me right now. I'm just looking for the frame width on an AD to see if my 1957 will fit. Thanks for the reply.
1/2 ton AD truck frames are narrow at the front and much wider at the very back, not parallel and hard to say what width it is, more like a range of widths.
Illustrated here, note front width and rear width in chart.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0202.htm
The 3/4 through 2 ton truck frames are 36" wide outside and parallel starting at the back of the cab.
The GMC 400 series and larger AD trucks are 34" outside the frame rails. From then on and still today most larger trucks are 34" outside the rails.
The frame that fits your truck best is the frame it came with, or the equivalent from similar truck in that model year range.
I'd suggest just driving the 52 for a good while and then figure out what you might want to change, if anything. They're pretty good trucks to start with. Give it a chance, might suit your needs just fine and if not you'll have a better understanding of what you do or don't like about it prior to making big changes.
•1952 Chevrolet 3800 pickup
---All pictures---
47-53 frames are pretty much the same except for minor attachments like shock and cab mounts. In 54 the new bed with flat instead of angled bed side rails went onto a flat frame instead of the kicked up one over the rear end housing. The 55.2 through 59 is a completely different frame in every way.
Evan
