1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 33 | Does anyone have a diagram for the instrument cluster on a 1959 Apache? I have the shop manual and Fig. 15 ("Instrument Cluster Electrical Loads"), in Section 12, looks like it is exactly what I'm looking for. The print is so small though that I can't even make out a single word. I was hoping that someone has a version that is readable, even if it's hand written on a napkin. Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | TF wiring .... assuming you're trying to figure what goes where, notice the wiring diagram has a line labeled "front of dash" - the components and connections are exactly as in the truck if you view the diagram from the drivers seat .... all the detail needed Bill | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Just take it to a Kinkos or some other copy place and have them blow it up.
Tommy 59 apache 1/2t 261 short stepside | | |
