3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 11 'Bolter | | 'Bolter Joined: Apr 2015 Posts: 11 | I took everything off my 230 to paint engine and add AC bracket above alternator. went to start had a little trouble with timing, but got it running good, but I have a sort of loud deep knock at idle like a rod bearing double knock and is intermittent, did not have be fore, I thought it was the water pump because of the extra pressure on v belt with AC, so I disconnected the belt and noise is still there. what could I have done?
Schetk
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Double check firing order, and timing. Bearings do not go bad after painting, so rule that out. Fuel pump tight?
Joe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Could you have dropped something down the carb or the manifold if you had the carb. off? Sounds like something rattling around in a combustion chamber. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
