| | | Forums66 Topics128,141 Posts1,056,779 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | I live in College Station, Texas about 1.5 hours from Houston. I was wondering if anyone out there knows of a good driveline/differential shop in Houston that could rebuild my Napco front axle and the rear Dana 44. I'm restoring a 1958 Napco 3/4 ton and I'm trying to get it to as near original as I can. Trying to find someone with attention for detail. Anyway, if anyone has any ideas please let me know.
Thanks, Craig
1953 3100 | 1958 3/4-ton NAPCO
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | | | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 | I didn't look very hard but there has to be someone around who has worked on them. I talked to a guy at Houston Drivetrain Service who actually knew what one was, I don't know that they could restore one and make it presentable enough for a detailed restoration. You might call Omar Lugo (lugoparts.com) at his place in Calif and see if he knows anyone in this area. He's a NAPCO guru.
I tackled mine myself. It's a dirty job but doable. That way I can be sure it's detailed and done to my satisfaction without someone slapping it back together with a bunch of dirty and rusty hardware and assorted parts going back on it.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Ditto Redline's comments. I did my own, doable but dirty. Just go slow. However, mine was half-ton running gear, which appears much easier than the 3/4 ton (from pictures anyway). My truck is a 3/4 ton, but I used 1/2 ton Napco running gear. Seems like it is much easier to get parts for the 1/2 ton running gear. don | | |
