2 members (baldeagle, 1 invisible),
90
Mod | | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi All, I am working on rusted fenders and I am not sure how to handle them. The metal is pitted, not rusted through, just pits. I grind and sand the old paint off and I am left with pits with rust in them. These are small bb size. Does this mean the fenders must be replaced? If I grind down to the bottom of the pits there will not be much metal left. I know better than paint over them but I am not sure what to do with them. Is something like por15 in order here, then fill with body puddy, prime and seal and then paint? I don't think it is practical to try to get all the rust out of the pits. Okay, I am sure you see where I am coming from. Ideas? Suggestions? Thanks! Rick in Va | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What year/model truck are you working on? There may be naw replacements available. If not, you may consider trying to find better ones at a swap meet or salvage yard rather than repairing the ones you have. Ypu are right, it'll be a lot of work to try to bring back fenders that bad, however POR-15 does have a filler that may work. It's called Resto-grip and is made to work with por-15.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | get phosphoric acid get a spray bottle and spray the rusty areas be carefule hardware stores cary it it turns the rust into somthing defferint and it kills it i just did my truck very happy with what it did | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I had/have the same issue with my 54 cab. I prepped the areas with phosphoric acid solution I got from Home Depot, cleaned off the residue, profiled the metal with 80 grit on a DA sander, skim coated it with filler and then sanded down with 120 & 320 grit paper prior to priming. The primer then filled in the remaining issues. | | | | | Joined: May 2006 Posts: 16 New Guy | | New Guy Joined: May 2006 Posts: 16 | I had a hood that was badly pitted. I had it blasted. if you blast it and all's they hand you back is the emblem....you need a new or used fender.if it is still solid, a skim of duraglass(polyester resin type bondo-water proof,hard as nails)works great. they also sell a "metal to metal type filler(eastwood) skim it keep movin | | | | | Joined: Sep 2004 Posts: 36 New Guy | | New Guy Joined: Sep 2004 Posts: 36 | Totally agree with Eagle117. I had some pitting after media blast on pieces of the box. I used Duraglass also with excellent results.
1959 Chevy Apache Stepside 4x4 2009 Chevy Silverado 2500HD Duramax/Allison LB Crew Cab
| | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Thanks for the input! I was hoping this is what was going to be said. I didn't think it was necessary to replace the fender just because the pits didn't come out. Thanks for taking the time to answer, I appreciate it! Rick in VA | | |
