10 members (Lightholder's Dad, Hanks custodian, Otto Skorzeny, Gray_Ghost, MickeyP, mick53, Gdads51, KCMongo, JW51, 1 invisible), 95 guests, and 2 robots.
Topics128,049
Posts1,055,658
#1206125 02/27/2017 5:09 PM
A little help please. What is the color of the metal trim around the door panel on my 1950 1/2T pick up?
If you post a link to a photo maybe someone could wager a guess. But we need to see it before guessing.
Or did you mean something else?
Give me ambiguity
or give me something else
Jhyp,
Maybe I am misunderstanding the question. But are you asking, if you purchase the metal trim around the door panel, what color is it? If that is what you mean, I believe that they are a shiny stainless finish. Anyway, that is the only color I have ever seen.
Good luck with your project.
Rugo
Steve Rugg
53 3100
Tim and some other guys can give you the concour answer. I painted mine brown near the color of the panels of my '54, but purposely not exactly.
I scuffed, primed with self etching, then primed and wet sanded. Bought some paints at a hobby shop to mix the color. Sprayed with an airbrush.
Lonnie
- Lonnie
My '54 3104
The color on my '50 1/2 ton was painted maroon. There was original paint on the back side that was in pretty good shape that I had color matched by the PPG dealer.I had a pint mixed up and it was more than enough.
Mike
My 52 had them maroon to match the cardboard panels also. Seems factory as backside same too.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
Moderated by  ndkid275, Phak1
