| | | Forums66 Topics128,163 Posts1,057,072 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 19 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 19 | All, with limited options for lowering the 3600 rear I came across the LMC 3 inch lowering springs. Has anyone used these? Thoughts | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | You can get those springs directly from Eaton/Detroit Spring... in stock height, 1,2, or 3 inch drop. I took my 3600 rear springs to the spring blacksmith recently and he set them up at 2.5" . I think it cost me $240 and they were completely disassembled and inspected during the process.
On a side note, If you are going to use a different rear axle, I am getting ready to measure my new axle setup for frame/driveshaft clearance, and there might be an issue with the center crossmember interfering with a one-piece driveshaft.... I might end up having to go with a custom two piece $$$ . Driveshaft guy says I need a 3.5" diameter shaft, as it's going to be about 60 inches long. At full bump stop I don't think a 3.5" one piece shaft is going to clear the crossmember. That would be a bummer.
I'll post my results here on the Hipo Shop forum.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2014 Posts: 19 'Bolter | | 'Bolter Joined: Feb 2014 Posts: 19 | Great advise and yes please post up your results. What did you do up front. I stayed old school and had SID do a drop axel for me. Love the results just gotta decrease my rake a little ( a lot) in the rear.
Gonna source thise springs and talk to some local guys. Thanks a ton or in this case a 3/4 ton. Rob | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | For the front I had Sid do a 2.5"drop... My truck is still in pieces, so I don't know how it's going to look. Good luck with your 3600!
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | You can always take out all but 3 or 4 of the rear springs. Gets you there on the cheap. You lose alot of load capacity though.
I've been looking at doing a complete leaf swap with either a Colorado spring pack or Ranger spring pack. Of course, I would need to buy new mounts and shackles too.
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Just a followup on my driveshaft- I installed a one piece 3.5 diameter driveshaft, but removed the triangular driveshaft bearing holder mounting plate from my center crossmember. This gave me all the driveshaft clearance I need.
