3 members (Gdads51, Otto Skorzeny, Barney1951), 62 guests, and 1 robot.
Topics128,080
Posts1,055,946
Members48,430
#1205770 02/25/2017 5:55 AM
2 Offline
Well I went wild, and decided to do some work to her so she will keep moving me. In the past few months and hopefully wrapping up this weekend I have done the following:
New kingpins and bushings - had one side that was going out and did the other because it was there.
Reconditioned springs and new pins and bushings at all spring hangers. If you haven't done this to your truck, I suggest considering it. It has taken what was a somewhat rattling ride and made a nice and quiet and even a somewhat more stable ride on the highway. Noticeable difference for sure.
While the hubs were off for the kingpins, I noticed I had a bearing giving up metal flakes. After some, -No- a LOT of searching:
New front wheel bearings and seals, and since I was in there and it has been nearly 20 years, new wheel cylinders on both sides, and relined brake shoes on one side, the other side had new relined shoes last year and they still look new.
Went to the rear, and found that what I thought wasn't much of an oil leak was more than enough to be a big problem. Pulled everything apart, and ended up with new wheel bearings and seals, an oil change, relined brake shoes, and new wheel cylinders.
Finished the drivers side rear this evening, and hopefully tomorrow will get the passenger side rear re-assebled and everything bled and adjusted and ready for the next 20 years wink.
1946 Chevy Pictures
1946 Chevrolet 2-ton. In family since new. Splash oiled 235, 4 speed main, 3 speed aux, single speed 6.17 rear. Original GM supplied 12' stake bed, paint on sideboards is still from the factory.
Ride Along Video!
Ride Along with a little load
Video Channel
That is an awesome truck. I watched a couple of the videos you posted to youtube, glad to see you are still using it for the work it was intended for.
1953 Chevy 3100 Pickup
1954 Chevy 6400 Grain Truck
1957 Pontiac Transcontinental
1958 Buick Limited 2 Dr
1968 Ford Galaxie 500
1974 Ford F-350 Flat Bed (Dump Bed), former Pioneer Seed Truck.
"Beer is proof that God loves us and wants us to be happy." ~ Benjamin Franklin
Good to hear that your 46 got some love and attention.
Lots more pictures
2 Offline
Thanks for the kind words. Passenger side all buttoned up and everything bled and adjusted. Looks like no leaks so far after a test ride into town today. It all wasn't cheap, but then again some of the parts that were replaced were 70+ years old...and I'm willing to bet a few of the replacement parts were on the shelf almost as long judging by the packaging. Had to rebuild a portion of the parking brake linkage, it broke when attempting to adjust it out to work with the new shoes and that was after a lot of oil and even using the torch to get it free...
I also forgot to mention the 6 new tires. She is ready for the ball now! Hopefully in a few weeks when the new shoes settle in, I can get everything adjusted back up and she will be essentially new from the frame down.
1946 Chevy Pictures
Ride Along Video!
Video Channel
