| | | Forums66 Topics128,139 Posts1,056,462 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 21 New Guy | | New Guy Joined: Mar 2016 Posts: 21 | Hello all, on the oil line across the top of the rocker assembly there is a clip that when rotated exposes a hole. What is the hole for and should it be covered with the clip? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The hole is there to stop the tube from siphoning and the clip is there to stop dirt from getting in. This is described in a GM document, I just don't know which one it is in. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I'm not picturing what you're talking about. I don't recall a clip with a hole under it. Do you have a photo? How to post a photo.
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I know the clip you're asking about and truckernix nails it. You also want to keep it positioned so as to deflect the oil that'll eventually squirt out back down towards the head. The oil can squirt straight out of the center valve cover vent slot if not deflected by that clip. Been there done that LOL. A pic of the clip | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I see all 216s are not created equal. My '38 has no such clip.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
