7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible), 82 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#1205976 02/26/2017 8:06 PM
Z
Z Offline
Do all the splines on the 5 spline drive gear look good ?
The splines on my gear are wider or flatter in some ares. I have never seen another gear so I have nothing to compare it to..
1953 chevy 1/2 ton
please let me know if you can access the pictures with below url
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Z
Z Offline
I can see the pictures just fine. Those are not spines but gear teeth and to me they look A OK.
1951 1 Ton Completed
I have never seen a speedo gear with flatten 'lands' as shown in you pics. My question is...what did the damage?
Z
Z Offline
Does anyone have a picture they could post of a drive gear so we can compare them to see the difference ????????
This might help
It is for a four speed transmission.
Z
Z Offline
Jorb...
Some of the lands or flutes or what ever they are called seemed to be flattened very similar to pictures that I posted of my drive gear....
Would you consider this gear to be worn badly ?
Z
Z Offline
If my speedo drive gear is shot then where can I obtain another one ?
Is it possible to file these lands where they are flattened so they would be less so ?????
Z
Z Offline
I also just noticed that the drive gear is chamfered and that side is where the lands are the widest, not sure if that means anything.
Jorb...
NO, It is only a speedo gear, there is not much force on it, there wouldn't be a lot of wear. It is only driving the speedometer cable.
If my speedo drive gear is shot then where can I obtain another one. ?
http://nwtparts.com ,Ask for John
Yes, But that is not how they were designed.
I believe that is normal.
1929 - 1954 Master Parts and Accessories Catalog
Group Number 4.337, Speedometer Gear
page 1
page 2
page 3
There are a lot of variables that go into getting the correct speedometer reading.
The above pages show: tire size, wheel size and ring & pinion teeth. Also possibly needed adapter.
Z
Z Offline
Jorb thank you for all the good info...
Z
Z Offline
I now have my speedometer back...
the cause of my problem was that I forgot to reinstall the 3/8 1" fine thread bolt that holds the front part of the universal flange to the output shaft. This allowed the flange to move so that the speedo drive gear moved slightly not allowing the drive and driven gear to mate up.. On this tranny the speedo drive gear is not pressed on to the main shaft it is held in place by the universal flange and bolt going into the end of the main shaft.
I had thought that the drive gear was damaged but it was not.
Thanks to all who helped me solve this problem.
Funny...I Did not have any bolts left over and my work space is immaculate so maybe a mouse took my bolt ?
