| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I am probably wrong, but this chassis looks odd to me. Can't put my finger on it. It is a '51 COE 2 ton (158" wheelbase)and maybe just that it's a little "stubby" is doing it, but everytime I look at it, it doesn't seem right. What do you think? BTW, it had an optional factory frame extension on the rear. Later someone welded another piece of channel over it for more strength and recently it was cut off about an inch or so from the standard frame (probably so it would fit on the trailer for shipping). http://s1276.photobucket.com/user/jsdesign2/library/51%20ceo | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jim Sears, the two crossmembers immediately aft of the cab mounting superstructure seem too close together to me. I have a 1939 Chev c.o.e. and 53 c.o.e. chassis, I'll have a look in the morning but it looks like a section of the chassis may have been removed. | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | That is indeed a original 158"in wheelbase COE chassis. Just like the one on my 48 5700 series COE out back. | | | | | Joined: Jan 2017 Posts: 3 New Guy | | New Guy Joined: Jan 2017 Posts: 3 | Part of the reason the chassis looks funny is because the outside rear wheels are not on it....should have duals...
1950 3/4ton w/235 & SM420 1956 BelAir w/235 & Powerglide converting to 261 & 200 4R 1955 1/2ton w/235 & SM420 1951 2 ton w/235 & SM420
