3 members (Otto Skorzeny, 1955 1 Series, Wheelie), 165 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
Z
Z Offline
Been doing some reading on my speedometer not working after tranny rebuild. ..The articles I read said the drive gear is pressed on to the main shaft but when I was taking the tranny apart I just pulled the drive gear off with my fingers and when I installed it again I just slid it on. So, if it should be pressed into place, why did I have a working speedo before the tranny rebuild ?
The tranny I have is believed by me to be a 318.
it has a 4 bolt side cover with the numbers 3686832 GM
The main case is stamped 591615.
Anyone have any thoughts before i pull this tranny back out while on my back and with the truck on jack stands.????????
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Zoe, I don't have an answer to your question but a suggestion for ease of answering your posts. Go into your profile and post the year and model for your truck. It makes it easier for the gurus to give the needed answers without having to ask extra questions themselves. Just a friendly suggestion not a critique for your posting style.🤓
Z
Z Offline
Thanks...just did it...
On the main shaft directly behind the rear bearing there should be a spacer (about 1/4" long) then the speedo drive gear, then the long pipe spacer, and last the yoke. If nothing is worn the bolt that holds the yoke to the main shaft should pinch all the pieces tight together so all parts turn with the shaft.
My Blog
Z
Z Offline
Dave....I now understand that the drive gear does "not have to press fit " as I had heard on youtube.
On close inspection I saw that the 1" bolt that holds the yoke to the main shaft was missing. I did not remember removing it but I must have. That missing bolt explains a lot and may cure my problem of the drive gear not lining up with the driven gear...the drive gear looks buggered up so I may need to obtain a new one if available.....I Will keep you posted.
Z
Z Offline
Pre 68 Dave.....your post solved my issue because you listed all the parts that would be inline to secure the drive gear in place and that all is held tightly together with that bolt. I had presumed that the drive gear was supposed to press on to the main shaft and could not figure out why it just slid on...........a special thanks to you...
Glad it all worked out!
My Blog
