7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible), 85 guests, and 2 robots.
Topics128,028
Posts1,055,414
Members48,422
#1205673 02/24/2017 5:43 PM
I have a 56,w/235. Got new temp. gauge (elect) and the sending unit will not thread into the head(threads are to big)Threads are 1/2.or 5/8. Head threads appear to be about 3/8 anyone else have this problem,and what is a solution?
In 1956, or later, the hole got larger for a larger electrical sender.
Either your engine is older than 1956, or you have a "leftover" 1955 2nd engine/block.
What is the engine serial number and the block date casting code?
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
The engine is out of a 55 wagon. So I guess I have to use plan B what ever that is. By using the reducer will that allow me to use the larger sending unit? And will it still read correctly?
Good luck with Plan B.
The adapter is to allow the older/smaller-hole mechanical "bulb" to fit in a newer/wide-hole head.
You have a smaller-diameter sender that needs to newer/wider hole (a later head).
If I understand this incorrectly, we'll soon hear corrections/clarifications.
makes sense to me. Thanks for your help
Sir Searchalot
Sir Searchalot
It seems Midpiner is saying he has a 3/8 pipe thread in the head and a 1/2 pipe threaded sender. The link shows a reducer, he needs the opposite. Find another hole somewhere that is xx ....or a xx (sender thread) to 3/8 MNPT reducer. This one is 5/8-18 straight internal threads to 3/8 MNPT I don't know what size your sender threads are. Measure them. The TS6 is 1/2 NPT. You may need This
The problem will be if the probe will fit down deep into adapter so as to "sense".
H Online: Content
Actually, the earlier head has a straight thread, same as a a 5/8" bolt, I believe, not a tapered pipe thread. The adapter is for a later model head with a 1/2" tapered pipe thread in it, to make it fit the sensing bulb for a mechanical gauge. I have seen people plug the small gauge hole and drill and tap the head for the proper pipe thread, but it is a tricky operation and the hole has to be drilled exactly right. Another approach is to put a later model upper thermostat housing with a threaded hole in it on the engine, and put the electrical sensor there, then use a short bolt and a copper disc to plug the original gauge hole.
Sir Searchalot
Sir Searchalot
As Jerry mentions, water outlet with sender Tap
Plan on tapping into thermostat housing and connecting wire there. Thanks again for all ideas.
Sir Searchalot
Sir Searchalot
Just to be sure, we are talking about a thermostat housing you can buy that has the treaded hole for sender. I guess one can be drilled and tapped. How about a TEE on the heater hose outlet?
