| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | I have a 56,w/235. Got new temp. gauge (elect) and the sending unit will not thread into the head(threads are to big)Threads are 1/2.or 5/8. Head threads appear to be about 3/8 anyone else have this problem,and what is a solution? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | The engine is out of a 55 wagon. So I guess I have to use plan B what ever that is. By using the reducer will that allow me to use the larger sending unit? And will it still read correctly? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good luck with Plan B.
The adapter is to allow the older/smaller-hole mechanical "bulb" to fit in a newer/wide-hole head.
You have a smaller-diameter sender that needs to newer/wider hole (a later head).
If I understand this incorrectly, we'll soon hear corrections/clarifications.
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | makes sense to me. Thanks for your help | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It seems Midpiner is saying he has a 3/8 pipe thread in the head and a 1/2 pipe threaded sender. The link shows a reducer, he needs the opposite. Find another hole somewhere that is xx ....or a xx (sender thread) to 3/8 MNPT reducer. This one is 5/8-18 straight internal threads to 3/8 MNPT I don't know what size your sender threads are. Measure them. The TS6 is 1/2 NPT. You may need ThisThe problem will be if the probe will fit down deep into adapter so as to "sense".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Actually, the earlier head has a straight thread, same as a a 5/8" bolt, I believe, not a tapered pipe thread. The adapter is for a later model head with a 1/2" tapered pipe thread in it, to make it fit the sensing bulb for a mechanical gauge. I have seen people plug the small gauge hole and drill and tap the head for the proper pipe thread, but it is a tricky operation and the hole has to be drilled exactly right. Another approach is to put a later model upper thermostat housing with a threaded hole in it on the engine, and put the electrical sensor there, then use a short bolt and a copper disc to plug the original gauge hole. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | As Jerry mentions, water outlet with sender Tap
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Plan on tapping into thermostat housing and connecting wire there. Thanks again for all ideas. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just to be sure, we are talking about a thermostat housing you can buy that has the treaded hole for sender. I guess one can be drilled and tapped. How about a TEE on the heater hose outlet?
