1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
Not that I'm trying to be cheap, but do you reckon if I snag one of those furniture dollies at HF for $8 that are rated for 1000#'s and extract the casters for one of these stovebolt special dollies that they will give me any runtime at all? I'm betting one of you guys have tried it.
dolly
Allen
1974 Stingray Corvette
I did buy a HF dolly when I was down visiting my mom and extracted the casters from it for just that purpose. It was cheaper than buying the equivalent casters at HF, and I was able to throw them in my suitcase to fly back home. So yes, I am trying to be cheap. grin
My plan is exactly what you have in mind, and I think the casters will give reasonable service life. I just haven't pulled the engine yet to start on the chassis work.
Why don't you just use the dolly whole and attach uprights to hold the motor?
I used the wheels from my HF dolly. It worked out great. Engine sat in the homemade cradle for 2 years and the wheels worked just fine the whole time.
Tried to think of a way to beef up the dolly itself but ended up finding the 4x4 and 2x6 approach was less time and effort in the long run.
-Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
I have 2 engines (both 250ci) in my garage now on HF furniture dollies. I bought the bigger size that cost around $13 each. I then built the dolly you see linked in the first post but I think I trimmed it some. Anyway, I just set the engine in the cradle and then set the cradle on the furniture dolly. I didn't bother to screw the cradle to the dolly either.
They both have stood the test of time. I am tired of pushing these 2 engines around and need to get them sold.
I certainly do recommend the larger size HF dollies and just set that cradle on top.
Big Bolt Forum Moderator
I have 2 of them as well, one has a 440 sitting on it and has been there for a few years, rolls fine when needed.
Mike
Here are pics of my larger size HF dolly with the cradle on top. Photobucket album - Engine Dolly - many pictures
1 Offline
I tried to get to your pics but on tablet it failed. Can you post some instruction as to how you built the cradle?
I just created a page on my website. It's under the Tips and Tricks Section. You can also LINK HERE to see pics on my website.
Lugnutz
did you ever try and start a motor on that dolly??
Originally Posted by evac34
Lugnutz
Short answer is no. The HF dolly wheels are not spread as far apart as the original design. Using the HF dolly makes it slightly less stable. I'm just extra careful when I push it around.
I built myself an engine run stand. Breaks down and takes up less room than my cherry picker. Engine Run Stand Video
That is what I did, works like a charm. I've never started a motor on it though.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
Well, I built the engine dolly first and then bought the furniture dolly later. I was pleased to see it was the perfect size. Once I sell the engine, I'll want to use the furniture dolly for other things. I find it to be less work to keep the furniture dolly as a separate piece.
Moderated by  MNSmith
