1 members (dunfire),
92
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | http://imgur.com/MLkIHk9My paint job looks pretty darn good coming right out of the booth. I'm getting close to taking delivery of the 'finished" truck and I'm bleeding $$$$ quite severely. The restoration shop (paint dept) is telling me that to cut and buff to "show" quality is another $2500-3000, which equates to around 30 hours. My question is: Is this a reasonable amount of time to get this done? There appear to be much less expensive options around the area. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Seems like a reasonable time to hand cut and buff for a 'show' quality job. Thats a lot of hilly curvy real estate to plow flat. (By hand)...
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Since you are happy with the paint, I would go with them. Having done this myself I know you can burn through the paint and have to redo. I'd rather them have that responsibility. What the heck, it's only $paper.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | Thanks guys. That makes sense. | | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | Depends on color and what you're after as an end result. A Barrett Jackson finish is worth it, a local driver show n shine definitely not.
Hoods and fender tops are looked at the most so maybe a "topside" cut is worth it? I have a Harley and it's cut polished on tank and top or fenders only... just a thought.
It's real easy to spend someone else's money but I'm not like that.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My 1954 Suburban took 24 total man-hours to cut-and-buff by 3 people (in one 8 hour day), 1 day after painting with PPG DCC 2-part, single-stage Urethane.
I was told you should/could do it by hand within 48 hrs. After that - a power buff would be needed - by a pro.
The price you quote is reasonable, but I agree with FootStomper. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | This sounds expensive to me. I have a difficult time spending that much on a paint job in the first place. As for buffing I have a problem spending that much when materials to do the job are less than $100. I guess that is why I do most of my own paint work.maybe I am just cheap. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Materials cost us a lot less than $100, but it took us 8 hrs x 3 people. We did it before the Urethane became rock hard.
It's the labor time that costs the $$$ if you have a pro do it.
If the paint has cured/totally-hardened, I'd have a pro do it, or leave it like it is. The original paint job was not buffed/polished. | | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Mine is costing me $1500 for them to fix a few spots, reclear coat since first painter screwed it up, and make it show quality. This included them taking fenders back off and reassembly.
Chris | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Just out of curiosity, I understand what buffed/polished is, what is cutting? | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | Cut = wet sanding with 1000-2000 grit sandpaper to knock down orange peel. Buff = machine polishing with progressively finer compounds and pads.
I did my own cut and buff; it was really scary taking sandpaper to my gloss black paint, yet surprisingly easy (even though paint had cured for 6 months). If you error on the side of caution (ie always start with finer paper and less aggressive compound, and keep away from edges so you don't sand through) it's a time-consuming but rewarding task that will make a world of difference in your paint job. The benefit to having your painter do it is, of course, if he screws up the repaint is on him.
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Materials cost us a lot less than $100, but it took us 8 hrs x 3 people. We did it before the Urethane became rock hard.
If the paint has cured/totally-hardened, I'd have a pro do it, or leave it like it is. The original paint job was not buffed/polished. Labor rate here is 43.00 a hr. Compared to a garage that's cheap,but that is all our local body shops can get from insurance company's , 24 hrs times 43 is $1032. Plus tax and materials. This sounds like a lot to me,but reality is they have to make a living ,and keep the doors open. Then I have to ask myself ,would I do it for ,what it cost? Sometimes I will and sometimes not. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | $43/hr for professional body work? Sounds like a good deal to me? | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | $43/hr for professional body work? Sounds like a good deal to me? Yes, I have 2 friends with local body shops. They both say the same thing about what they can charge insurance. 1 is what is considered a pro shop in the body shop world. He has several employees that work for him. He has been saying for years that rates need increased. It's not right that a garage can charge $60 - $80 hr for machanic work,but a body shop can't. I guess just to much competition here. | | | | | Joined: Mar 2010 Posts: 10,290 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,290 |
| | | | | Joined: Oct 2015 Posts: 338 Shop Shark | | Shop Shark Joined: Oct 2015 Posts: 338 | At the risk of derailing the thread... body shops in all regions complain about the labour rate. Some get the new higher negotiated rates only to find out the insurance companies start writing off vehicles so no repairs are done by any shop. Or, they can't use OEM panels and have to work with misfitting aftermarket ones that end up costing them more time and work to complete the job.
One needs to careful what they wish for... | | | | | Joined: Mar 2008 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 55 | Paint work is not cheap anymore. Cut and buff time depends on the paint. Ask the people that supplied the paint they should know. Some if you don't get it in the window you will never buff it.Also go the extra step down to 3000 grit and it makes it so much easier to buff. Wet sand with a little dish soap in water helps.Use the correct pads for the compound you are using and I usually do three steps to get final buff. 3M and a company called Presta make a kit. A good variable buffer and a good touch. Tape high spots also do them by hand. Very easy to burn paint. Hope this helps. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | So the days of the MAACO $199 any car any color paint job are gone!? Uh oh, better get MAACO.
Larry
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | $43/hr for professional body work? Sounds like a good deal to me? Seems common in the body biz.............They quote low hourly rate and then double the hours .......so it comes out in the wash. | | |
