0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hello all, I did a frame off resto on my 1957 3100 Chevy truck. The truck is bone stock and has a new wire harness installed. The battery is not charging. I have 11 volts at the battery and 14 at the voltage regulator and generator. Where could the problem be and why the battery is not charging? Could it be at the starter or amp gauge? Can I bypass the gauge and see if the gauge is the problem? How do I do that? There is two red wires at the gauge and one black wire. Thanks 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | Which terminal at the regulator has the 14V? If the "Bat." terminal is showing that voltage the problem is between the regulator and the battery, possibly an internal open circuit at the ammeter. Temporarily, remove all the wires from the ammeter and bolt them together. If the voltage rises at the battery terminals, replace the ammeter.
There are several other possibilities. You really need to find someone who can do a detailed circuit trace, as it's almost impossible to cover all the possible problems long distance unless you have an extensive background doing electrical work. The "new wire harness" concerns me- - - -there are a lot of ways to get a wrong connection. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | First try polarizing the gen. Touch a piece or wire from the bat term. to the arm. term. at the regulator. If that doesn't do it put a test wire between the bat. term. on the regulator to the pos. post on the bat. If it works then you have an open in the circuit which could be the amp. meter. Test the amp. meter like HRL said. Another test is to ground the field term at the gen. or reg. & try it. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you guys. Forgot to mention the gen has been rebuilt and new volt reg. I did polorize. When I sent the gauge cluster out to be rebuilt I wonder if they used cheap China parts for the gauges. Will bypass the amp gauge and see what I get.
Thank you. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make sure the grd. . & fld. wires from the reg. to the gen. are not crossed. It's easy to do.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi guys, I removed all three wires from the back of the amp gauge. Still showing 11.3 volts at the battery. 14V at volt regulator and generator. Could it be the wire coming from the BAT wire on the regulator? 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | You still haven't told us WHICH wire at the regulator has the 14 volts. If it's only the ARM wire, you have a bad regulator. If the BAT wire at the regulator is showing 14V you have an open circuit between the regulator and the back of the ammeter. Try running a temporary 10 gauge jumper wire from the BAT terminal of the regulator to the battery cable attached to the starter and then check the battery terminal voltage with the engine at fast idle. Jerry
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you Jerry, Sorry about that. There is 14V at the BAT and at ARM. I ran a wire from the BAT side of the volt reg to the starter. There is 14V at the wire I ran but when I attach to the starter and check the battery it is still showing 11 volts. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Problem fixed. Voltage regulator not grounded. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
