| | | Forums66 Topics128,162 Posts1,057,049 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | Hi all well I started my 216 eng in my 42 chev truck and it lasted about 5 min After i pulled it down again the crank and bearing on #4 rear main damaged so I am looking for another one as my crank is already 30 th under size or does some have a 40 th set I live in QLD Australia cheers Justin | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | A well-equipped automotive machine shop can weld material onto the shaft and regrind it if you can't locate another shaft. The process is called "submerged arc welding" and it requires a special MIG wire welding machine. At one time, a Federal-Mogul main bearing set # 648M was available all the way down to .060" undersize in .010" increments, but they might be very difficult to find. Another 216 main bearing set is listed under part # 484M with 10, 20, 30 and 40 undersizes. I am not sure which set would be correct for your engine. Jerry
| | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | Thanks I have had a talk with my machine shop and he is going to try getting another set of bearings not alot around but will keep looking Cheers Justin | | |
