4 members (jmoore, Donf, MikeStone1953, texas46), 96 guests, and 1 robot.
Topics128,278
Posts1,058,251
Members48,483
#1203818 02/11/2017 2:22 AM
Hi all well I started my 216 eng in my 42 chev truck and it lasted about 5 min
After i pulled it down again the crank and bearing on #4 rear main damaged so I am looking for another one as my crank is already 30 th under size or does some have a 40 th set
I live in QLD Australia
cheers Justin
A well-equipped automotive machine shop can weld material onto the shaft and regrind it if you can't locate another shaft. The process is called "submerged arc welding" and it requires a special MIG wire welding machine. At one time, a Federal-Mogul main bearing set # 648M was available all the way down to .060" undersize in .010" increments, but they might be very difficult to find. Another 216 main bearing set is listed under part # 484M with 10, 20, 30 and 40 undersizes. I am not sure which set would be correct for your engine.
Thanks I have had a talk with my machine shop and he is going to try getting another set of bearings not alot around but will keep looking
Cheers Justin
Moderated by  Rusty Rod
