0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 36 | Could oil, seeping/leak,be coming from head gasket? Don't think its coming from valve cover gasket.Thanks,Dennis
1955 1st. 235 P/U stock | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | if the engine runs OK (good compression) and there's no coolant in the oil or vice versa - its probably not your head gasket. i bet it is the valve cover gasket even if you don't think it is. those have a large sealing area and just four screws holding it on. | | | | | Joined: Jan 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 36 | Thanks,i agree. Same as carb.,not enough bolts.4 on carb also.Just wasn't sure what goes on between block=head,if it could leak. Oil is clear. Runs great.Will have to check compression..Thanks,Dennis | | | | | Joined: Jan 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 36 | Best place to buy good valve cover gasket? Sure you're right..Thanks,Dennis | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I have had a fresh rebuilt 235 leak oil between the head and the block. To fix it, I warmed it up fully, then re-torqued the head bolts with a newer torque wrench. I believe that I had used the old torque wrench for a breaker bar 18 or 19 too many times.  Carl
| | | | | Joined: Feb 2004 Posts: 29,880 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,880 | The torque wrench I use doing warranty claim inspections gets calibrated once a year. It's surprising how many cars I find with loose lug nuts after tire changes, wheel balancing, etc. from places like Firestone, Goodyear, and a bunch of the other national franchise places, usually after a wheel parts company with the vehicle! Jerry
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | To Carl's point, many head gasket manufacturers recommend doing a re-torquing after the engine has warmed up when installing a new head gasket by backing off the head bolts by 1/4 turn one bolt at a time and re-torquing at the correct spec...90 foot pounds for a 235...using the normal head bolt tightening sequence. My guess is that many head gaskets get installed on a cold engine and never get this done.
Matt | | | | | Joined: Jan 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 36 | Thanks to all of you! Will give it a try!! | | | | | Joined: Jan 2017 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2017 Posts: 36 | I read after warmed up re-torque from Matt. But do you let get cool before re-torquing? Hope that makes sense..Not a new re-build 9,000 mi. since done. | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | Torque the bolts with the engine at fully warmed up condition.
