| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | its a pre 54 due to the waterpump being small and high but i cant seem to find info on this casting. Block # | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My info shows that is a Canadian 216.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Anything else? was it truck, car? does it narrow down a year? | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | This info you found is it online?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Unfortunately I only have a picture and a note about that symbol and number, but not where I found it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2017 Posts: 62 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 62 | I have the same block, and the spotty info I have gathered from the forums is it is a Canadian 216. Mine has what I assume to be a date marked behind the starter (F 9 2) meaning June 9, 1952.
Mine also has a short side cover, which is a characteristic of the 235 but apparently a short run of 216s also shared the same block molds as the 235.
1951 GMC 9430 long box w/ hoist 1952 GMC 9430 long box w/ hoist (sold)
