0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | I need to replace/repair the front fenders... looking for info
| | | | | Joined: Mar 2004 Posts: 6,232 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,232 | Welcome to the Stovebolt  If you look for fenders remember, 1956 and 1957 Series 5000, 7000 and 9000 all share the same fenders. It might be faster and cheaper to repair what you have. Mike B
| | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | The fenders will be a challenge. The steps and risers will be the first step, the rest of the truck is in great shape. Thanks for the input. | | | | | Joined: Aug 2015 Posts: 11 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 11 | Mike B, what is the difference between the 55 & 56-57 fenders. Thanks. Roger
1955 5400 Lcf Cab going on p30 chassis 1949 3100
| | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | 55 fenders are one year only. The flare around the wheel well is smaller 56 and 57 are the same and have a wider flare. Cab flare is also different on 55 than 56 and 57. | | |
