5 members (Eisenholtz, Otto Skorzeny, Dakota38, KingG, Hugh63c10), 45 guests, and 1 robot.
Topics128,022
Posts1,055,386
Members48,422
#120448 05/03/2006 11:52 AM
How do I keep my door adjusted on my '49? They sag to the rear. I get them adjusted and it only lasts for a few months and then it's hard to open and close them again. I tried flat washers and lock washers on the bolts, but it still does it. Any ideas? Thanks much.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#120449 05/03/2006 1:00 PM
I am having the same problem with my '49 passenger side door. With me it was not being able to tighten the strike tight enough. The strike plate would work itself loose and I would be back slamming the door again. This weekend I decided to take the entire door off and replace the hinge pin, springs, etc. What I found was the hinge pin had worked its way half way out of the hinge which caused the door to sag to the rear. There are too many people on this board better able to explain "exactly" what to do to adjust your door, but basicly you need "good" parts to start with and tighten (loctite?) all fasteners so they don't move when it is adjusted properly.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#120450 05/03/2006 6:34 PM
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=43;t=000009
#120451 05/03/2006 11:54 PM
Sorry about posting here. Just noticed there was an entire forum on doors. Guess I need to look before I leap!
#120452 05/05/2006 6:08 AM
no problem, pablos, this is the normal place to ask body questions.
Paint & Body Shop moderator
#120453 05/06/2006 2:50 AM
If I remember correctly, they only had "star washers" under the bolts when they were original.
I think your washers under the lock washers may be the problem.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
