2 members (LAROKE, Phak1), 57 guests, and 4 robots.
Topics128,179
Posts1,057,162
Members48,465
Hi all,
I have a 1955 2nd series 6400. It has the two speed rear axle. I am trying to clean and prep for painting. I would like to drain the oil out, clean the sludge and refill the oil, however, I am a bit confused on how to go about it. I do not find a typical drain hole on it. I have read some posts to remove the bottom bolt from the cover plate and drain through that. But then how do I refill and to what level? Any tips and pictures would be a great help.
1955 Chevy 6400 2-Ton
LewyBoys' Garage
Big Bolt Forum Moderator
pull the rear cover to drain. There should be a fill plug on the rear cover, right about in the middle, a bit to the driver side. Fill to the bottom of that plug. Online manual says it holds 16 pints.
http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0457.htm
Mike
Crusing in the Passing Lane
If there is sludge in it, fill with diesel and drive gently, then drain and refill.
Ed
You can drain 95% of it by removing the lowest bolt on the rear cover. If no oil comes out at first, take a small screwdriver or scribe and poke in the hole. It may be blocked by sludge.
1950 4100 - unrestored and driven weekly for almost no reason at all.
if any water comes out pull the cover so you can get it all out.
•1952 Chevrolet 3800 pickup
---All pictures---
Check to see if there is a small pipe plug on the top of the pinion casting. If so,remove it when you refill. It will vent the pinion bearing area and allow the oil to fill faster.
Jack up a wheel, and add a quart of Diesel fuel, then run the truck in high gear at idle for a few minutes. The gears will circulate the solvent and do a better job of cleaning than you can possibly do by removing the cover. Drain, let it sit overnight, and refill with fresh lube.
Thank you all for your help.
LewyBoys' Garage
