13 members (Bill Hanlon, Oldcaliforniakid, Southerntruck, D B Cooper, Peggy M, Jims46, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 2-Ton, 2 invisible), 81 guests, and 1 robot.
Topics128,049
Posts1,055,674
58 1/2 ton with 235 engine
Does anyone have a picture or a link to a picture of the bracket that the throttle cable mounts to? The 235 has the stock one barrell carb. Thanks
Sir Searchalot
Sir Searchalot
This? or This? A FAM might help.
Here's one
Thanks so much. That's exactly what I needed to see.
I have a related question. I have the bracket on top of carb and understand how that part works to secure the choke and hand throttle cables.
However, once you thread the hand throttle cable through the linkage rod, and secure the end with a cable stop....is there anything else that's supposed to hold the linkage rod to the carb's throttle lever? My truck used to have a small cotter pin through there, so that's the way I put it back together. But that seems to be incompatible and doesn't allow the hand cable to slide up and down. My short term solution is just skipping the hand throttle cable and putting the cotter pin in that hole.
Gotta be missing something. The hand cable stop doesn't seem sufficient to hold the linkage rod to the carb's throttle lever.
1951 3100
3B Offline
Hy JW51, it is the throttle cable itself passing through the hole in the throttle linkage which secures the linkage to the carb. Many thousands of vehicles worked like this successfully for years. The cable stop only came into play when the hand throttle was used, hope that helps.
Sir Searchalot
Sir Searchalot
As 3B says, the stop/wire is the only thing holding link rod to lever so that the foot throttle can operate independent of the hand throttle. The "cable" is the whole thing. We need to say sheath and wire, maybe, if we need to be specific.
Makes sense. Probably why the throttle cable bound up and broke free the first time I tried to use it. Previous owner also had a cotter pin in the same hole.
It was the "wire" that bound up originally. Not the entire cable assembly.
1951 3100
