2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | HI, can any one tell me if what i read is true?closed tube rear end in all pass car & half ton chevy trucks are the same? (49-54)THE guts. I need gears for a 4:11 and there is one on ebay that looks like what i need. THANK for replies. BJF | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | TRUCK HAS 5 stud axles not 6 stud does it matter? THANKS BJF | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | OK, maybe you could tell me what to look for so i can identify what i have in this truck. Markings on gears or what truck rear ends where used. exploded views of these rear ends ( CLOSED shaft) all look the same. THANKS BJF | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1940-53 1/2 ton truck 4.11 gears will be the same. You should put an ad in parts wanted section here, there should be plenty laying around from 3.55 conversions.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2014 Posts: 74 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 74 | | | |
