3 members (KEVINSKI, Cosmo, ShopRag), 91 guests, and 9 robots.
Topics128,187
Posts1,057,212
Members48,465
HI, can any one tell me if what i read is true?closed tube rear end in all pass car & half ton chevy trucks are the same? (49-54)THE guts. I need gears for a 4:11 and there is one on ebay that looks like what i need. THANK for replies. BJF
TRUCK HAS 5 stud axles not 6 stud does it matter? THANKS BJF
Not the same.
OK, maybe you could tell me what to look for so i can identify what i have in this truck. Markings on gears or what truck rear ends where used. exploded views of these rear ends ( CLOSED shaft) all look the same. THANKS BJF
1940-53 1/2 ton truck 4.11 gears will be the same.
You should put an ad in parts wanted section here, there should be plenty laying around from 3.55 conversions.
My Blog
THANK YOU SIR.
