0 members (),
54
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | What is the correct GM casting number for a 54 Chev 3100 235 Hydra-Matic water pump? Is it 839403? Is there a part number associated with this casting number? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The main thing to look for is 235 engine and 3/8 inch fan belt (1953-1955st).
I think the Hydra-Matic makes no difference to the 1953-55st water pump. But, the Master Parts Manual says "except Automatic transmission" - I do not know why (Greg Hill or other H-M person might know). Maybe the PowerGlide 235 used a different water pump (maybe pulley diameter - I am guessing here).
I have a regular 1954 235 engine's water pump on my 1954 3100 Hydra-Matic engine.
CARDONE SELECT 5511510 AIRTEX AW108N ( they say "except Hydra-Matic" - maybe someone knows why?)
| | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | Is the regular water pump casting 839403? I have looked at those same parts books and the confusing part is that GM part 3836084 states for 53-55 Pass/Comm (except HT). GM part 3836223 states 54-55 Comm with HT (with trans cooler). I believe the trans cooler was only on 1 ton and 1.5 ton trucks. Hopefully someone has a stock water pump on their Hydra-Matic that can shed some light. Thanks for your input. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have two 1954 1/2 ton 235 engines that came with Hydra-Matics - they had/have stock water pumps. As I posted above, they have the same water pump as was used on the 1954 standard transmission truck 235 engine.
I only have one of those engines in NC. I cannot see the casting number.
It looks to me that the two parts manuals that I have have slightly different/conflicting/confusing listings. I think the Hydra-Matic transmissions that came with an optional cooler used a different water pump (they must have been water/coolant cooled?). | | | | | Joined: May 2015 Posts: 39 'Bolter | | 'Bolter Joined: May 2015 Posts: 39 | The stock GM water pump w/ 3/8" groove pulley on all 53-55(1st) 3100 235 engines, regardless of transmission, appears to be Part# 3836084 changing to Part# 3774211 in Feb 1960. The Casting number for both is 839403. I have no idea why the parts catalogs always states except H.T. If I'm wrong please let me know. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
