| | | Forums66 Topics128,185 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 7 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 7 | What is the name and code for the gray (with slight hint of blue) for the standard interior of a 1957 GMC truck? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Oct 2016 Posts: 7 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 7 | Tim,
Thank you for the color chart, but I am looking for GMC colors. Mine is a 57 one ton (253) and the body is Aqua Blue and the trim is Dover White. This was a popular color scheme. What I am looking for is the name/code for the greyish blue for the interior. The deluxe cabs seem to be painted the exterior color but I am guessing that the standard cab had the grey color. I sense that I am plowing tilled ground: others must have been though this process.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Oops, sorry Gates, I must have been drinking that morning. | | | | | Joined: Apr 2010 Posts: 23 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 23 |
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida' that she's cherry.
| | | | | Joined: Oct 2016 Posts: 7 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 7 | Up here we call a "fetcher" a "gopher" as in "go for" something you are told to get. The gopher is not to be confused with a woodchuck. A "woodchuck" is the guy who lives farther down the dirt road than you do. With that out of the way, I have read about the Marble Gray but it is usually in the context of a discussion of Chevy. I thought that Chevys used a light gray that Jimmy Carter sells. I thought that GMC used a darker gray. Mine is a bluish gray. I did a fruitless search for a paint chip for the Marble Gray to see the color. Is it true that there is no offset PPG # for the color? | | | | | Joined: May 2014 Posts: 92 Shop Shark | | Shop Shark Joined: May 2014 Posts: 92 | I'm no expert, but back about two years ago I was hot on the trail for interior paint for my 58 Chevy 1/2 ton. The conclusion I reached, which is open for correction by those who are the experts, was that interior colors did not appear on the color charts for these trucks. I ended up getting the Jim Carter paint, but I don't think it was the actual color of my Granddad's 58. To my feeble memory, that paint was gray but it had a slight metallic sheen to it. Since I wasn't going for 100% "factory" correct anyway, I went with the Jim Carter and am happy with it. | | |
