1 members (Samantha), 45 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#120403 04/24/2006 2:27 AM
Several of the new body panels I bought for my truck have the black EDP coating on them. What is the best way to prep the coating for further bodywork? Any help would be greatly appreciated.
#120404 04/24/2006 2:41 PM
Anonymous
Unregistered
Anonymous
Unregistered
Some of the coatings I have seen on patch panels were less than secure and I used a wire wheel on the grinder to remove it before installing the patch.
#120405 04/24/2006 3:30 PM
Check it with a rag soaked in lacquer thinner. Rub on it and see if it comes off on the rag. If it doesn't safe bet it is just fine to leave there. A true "E" coat is the best base for your primers and paints you are going to find. The problem is whether the company who made your parts uses a quality "E" coat primer.
If it is insoluble (found with the rag rub test) I say you are in pretty good shape.
Another thing is if while sanding you hit bare metal on it, look to see how well it is hanging on to the metal. This goes for anything you are sanding for paint. If it looks like the edge of the feather is "sharp" and you could get a fingernail under it or something like that, strip it. If if feathers off nice, it is hanging on fine.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
