| | | Forums66 Topics128,140 Posts1,056,467 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | Just finished media blasting some old aluminum rims and some finned alum valve covers. I want to paint this to match the truck. No powder coating! Is there a specific method of painting alum rims? Special primers/paint/clear? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | aluminum oxide primer - Rusteoleum & Hammerite have it - preferable to zinc chromate, the other choice
Bill | | | | | Joined: Feb 2006 Posts: 20 Junior Member | | Junior Member Joined: Feb 2006 Posts: 20 | Bill's right on the money. You have to use the primer made for aluminum it will seal the aluminum and give the paint something to stick to. Al
Allan S Langley B.C Canada
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Epoxy primer is the best bet.
Brian
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
